raulbs Publicado 7 de Diciembre del 2006 Denunciar Compartir Publicado 7 de Diciembre del 2006 Despues de montar el tempomat, configurar cierre confort y poner los intervalos de servicio a 15.000 km, faltaba un Auto-Scan. Aqui están los resultados. He mirado los códigos de errores y me quedo igual. Seguro que alguien me orienta. Gracias. VAG-COM Version: Release 311.2-N Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 Address 01 ------------------------------------------------------- Controller: 038 906 019 LJ Component: 1,9l R4 EDC G000SG 4910 Coding: 00002 Shop #: WSC 63351 WAUZZZ8E54A135831 AUZ6Z0C0345238 1 Fault Found: 18062 - Please check DTC Memory of Instrument Cluster P1654 - 35-10 - - - Intermittent Readiness: N/A Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front 3429 Coding: 04255 Shop #: WSC 06435 1 Fault Found: 65535 - Internal Control Module Memory Error 00-00 - - Address 08 ------------------------------------------------------- Controller: 8E0 820 043 AA Component: A4 Klimaautomat 1319 Coding: 00000 Shop #: WSC 63351 No fault code found. Address 09 ------------------------------------------------------- Controller: 8E0 907 279 F Component: int. Lastmodul RDW 0517 Coding: 00001 Shop #: WSC 63351 No fault code found. Address 15 ------------------------------------------------------- Controller: 8E0 959 655 J Component: Airbag 8.4EP 1002 Coding: 0010602 Shop #: WSC 63351 No Faults Found or DTCs not supported by controller or a communication error ocurred Address 16 ------------------------------------------------------- Controller: 8E0 953 549 N Component: Lenksáulenmodul 0611 Coding: 00041 Shop #: WSC 06435 3 Faults Found: 01303 - Telephone Transceiver (R36) 49-00 - No Communications 01301 - Control Module for Voice Recognition (J507) 49-00 - No Communications 01426 - Controls in Steering Wheel (E221) 49-00 - No Communications Address 17 ------------------------------------------------------- Controller: 8E0 920 900 M Component: KOMBI+WEGFAHRS. RB4 D42 Coding: 00101 Shop #: WSC 19410 WAUZZZ8E54A135831 AUZ6Z0C0345238 1 Fault Found: 00562 - Sensor for Oil Level/Temperature (G266) 27-00 - Implausible Signal Address 45 ------------------------------------------------------- Controller: 8E0 951 177 Component: Innenraumueberw. 0704 Coding: 00001 Shop #: WSC 00000 No fault code found. Address 46 ------------------------------------------------------- Controller: 8E0 959 433 BC Component: Komfortgerát T3B 1311 Coding: 06762 Shop #: WSC 63351 1 Fault Found: 01370 - Alarm triggered by Interior Monitoring 35-00 - - Address 56 ------------------------------------------------------- Controller: 8E0 035 186 D Component: concert II GRO 0004 Coding: 01005 Shop #: WSC 06325 2 Faults Found: 00466 - Control Module for Steering Column Electronics (J527) 49-00 - No Communications 00858 - Connection: Radio ZF Output to Antenna Amplifier 36-00 - Open Circuit End ------------------------------------------------------- Responder Enlace al comentario Compartir en otros sitios web More sharing options...
michobicho Publicado 8 de Diciembre del 2006 Denunciar Compartir Publicado 8 de Diciembre del 2006 hay que explicarte todos los errores que faenon mas arriva tienes dct del vag si hay alguno que te interesa mas dilo e intentaremos ayudarte Responder Enlace al comentario Compartir en otros sitios web More sharing options...
