relentizador Publicado 23 de Diciembre del 2006 Denunciar Compartir Publicado 23 de Diciembre del 2006 haber si alguien sabe los errores que me salen con el vag-com: VAG-COM Version: Release 311.2-N Chassis Type: 4D - Audi A8 D2 Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56,65,76 Address 01 ------------------------------------------------------- Controller: 4D0 907 409 A Component: 3.3l/4VTEDC G600AG D03 Coding: 00016 Shop #: WSC 08004 WAUZZZ4DZ1N001413 AUZ7Z0Y1414955 1 Fault Found: 17567 - Signals from MAF-1 and MAF-2: Implausible Correlation P1159 - 35-10 - - - Intermittent Readiness: N/A Address 02 ------------------------------------------------------- Controller: 4D0 927 156 AA Component: AG5 01L 3.3lTDI RdW 1516 Coding: 00001 Shop #: WSC 08004 No fault code found. Address 03 ------------------------------------------------------- Controller: 4D0 907 389 E Component: ABS/ESP allrad D46 Coding: 08357 Shop #: WSC 02313 No fault code found. Address 08 ------------------------------------------------------- Controller: Note: Excessive Comm Errors Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 4D0 919 033 CA Component: D2-KOMBIINSTR. VDO D29 Coding: 00180 Shop #: WSC 02313 WAUZZZ4DZ1N001413 AUZ7Z0Y1414955 No fault code found. Address 35 ------------------------------------------------------- Controller: 8L0 862 257 G Component: ZV-Pumpe, DWA, Funk D11 Coding: 15179 Shop #: WSC 02314 5 Faults Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 00991 - Interior Lights 28-00 - Short to B+ 00955 - Key 1 09-00 - Adaptation Limit Surpassed Address 45 ------------------------------------------------------- Controller: 4D0 951 177 B Component: Innenraumueberw. D06 Coding: 00001 Shop #: WSC 00000 No fault code found. Address 55 ------------------------------------------------------- Controller: 4B0 907 357 C Component: dynamische LWR D03 Coding: 00001 Shop #: WSC 131071 No fault code found. Address 65 ------------------------------------------------------- Controller: 4D0 907 273 Re Component: ifendruckueberw. D105 Coding: 22140 Shop #: WSC 02324 2 Faults Found: 65535 - Internal Control Module Memory Error 00-00 - - 01477 - System Switched Off 35-00 - - End ------------------------------------------------------- como resetear el indicador de service ,gracias de antemano cualquier informacion es buena Responder Enlace al comentario Compartir en otros sitios web More sharing options...
