Wenas a todas, pues el otro día en una kedd del club golf en el opcion uno me conecto el portatil y me puso el cable del vagcom nunca lo habia echo y me dio estos errores pero no tengo nada ni idea.
Tengo un repro, ¿tendra algo ke ver tantos errores con la repro?
VAG-COM Version: Release 311.2-N
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01 -------------------------------------------------------
Controller: 8L0 906 018 K
Component: 1.8L R4/5VT G 0002
Coding: 05610
Shop #: WSC 06313
7 Faults Found:
16487 - Mass Air Flow Sensor (G70): Signal too High
P0103 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-10 - - - Intermittent
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-10 - - - Intermittent
16944 - System Voltage Malfunction
P0560 - 35-10 - - - Intermittent
17925 - Main Relay (J271): Electrical Malfunction
P1517 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8N0 907 379 C
Component: ABS/EDS 20 IE CAN V003
Coding: 13504
Shop #: WSC 06435
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8L0 8 ö8 L08
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8L0 920 930 F
Component: AB-KOMBIINSTR. VDO D05
Coding: 01044
Shop #: WSC 00321
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0X1137794
Address 22 -------------------------------------------------------
Controller: 02D 900 554 B
Component: HALDEX LSC ECC 0006
1 Fault Found:
01155 - Clutch
04-00 - Mechanical Malfunction
Address 35 -------------------------------------------------------
Controller: 8L0 862 257 G
Component: ZV-Pumpe, DWA, Funk D11
Coding: 13130
Shop #: WSC 06313
6 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01365 - Lock/Unlock Switch: Interior
29-00 - Short to Ground
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00000
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 55 -------------------------------------------------------
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00002
Shop #: WSC 06313
Address 56 -------------------------------------------------------
Controller: 4B0 035 186
Component: Radio D01
Coding: 00201
Shop #: WSC 06325
1 Fault Found:
00856 - Radio Antenna
36-00 - Open Circuit
End -------------------------------------------------
Coding: 05610
Shop #: WSC 06313
7 Faults Found:
Coding: 13504
Shop #: WSC 06435
Coding: 01044
Shop #: WSC 00321
1 Fault Found:
01155 - Clutch
Coding: 13130
Shop #: WSC 06313
6 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00956 - Key 2
Coding: 00001
Shop #: WSC 00000
No Faults Found
Coding: 00002
Shop #: WSC 06313
Coding: 00201
Shop #: WSC 06325
1 Fault Found:
jod**!! yo no entiendo mucho del Vag, pero yo repeteria con otra vez el Vag-Com
a que llevas montado en el coche ?? 270cv no veas no!! tiene que ser un maquinon!
