Hola foreros.....Ayer me llego el cable con el VAG-COM de pandatti y hoy he hecho un test al coche y me salen los siguientes errores:
VAG-COM Version: Release 311.2-N
Chassis Type: 8N - Audi TT
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01 -------------------------------------------------------
Controller: 8N0 906 018 AQ
Component: 1.8L R4/5VT 0002
Coding: 11500
Shop #: WSC 01236
TRUZZZ8NX21036055 AUZ5Z0B5066014
1 Fault Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8N0 907 379 G
Component: ESP FRONT MK60 0101
Coding: 0019469
Shop #: WSC 01236
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00040
Shop #: WSC 01236
1 Fault Found:
00603 - Footwell/defroster Flap Positioning Motor (V85)
41-10 - Blocked or No Voltage - Intermittent
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8N1 920 930 Q
Component: KOMBI+WEGFAHRS. M73 D14
Coding: 00044
Shop #: WSC 26832
2 Faults Found:
01304 - Radio
49-10 - No Communications - Intermittent
01305 - Databus for Infotainment
37-10 - Faulty - Intermittent
Address 35 -------------------------------------------------------
Controller: 8N8 962 267
Component: Zentralverrieg. D06
Coding: 06755
Shop #: WSC 01236
1 Fault Found:
00956 - Key 2
09-10 - Adaptation Limit Surpassed - Intermittent
Address 55 -------------------------------------------------------
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00009
Shop #: WSC 01236
Address 56 -------------------------------------------------------
Controller: 4B0 035 186 G
Component: concert II GRO 0008
Coding: 00000
Shop #: WSC 01236
4 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
00852 - Loudspeaker(s): Front
36-10 - Open Circuit - Intermittent
00856 - Radio Antenna
End -------------------------------------------------------
Tengo entendido que el primero es normal y que no tiene nada que ver con un problema...pero los demas............no se como solucionarlos, alguien me podria decir como se solucionan?esque son bastantes, y ademas, la radio funciona bien, pero me aparece error en los altavoces delanteros, y no se como solucionarlo.Gracias
17978/P1570 - Engine Start Blocked by Immobilizer
[edit]Possible Symptoms
Engine starting but stalling immediately
[edit]Possible Causes
Key(s) not matched
Instrument Cluster not matched
Engine Control Unit (ECU) not matched
Engine Control Unit (ECU) Power Supply faulty
[edit]Possible Solutions
Match Key(s)/Instrument Cluster/Engine Control Unit (ECU)
Check Engine Control Unit (ECU) Power Supply (Relay)
[edit]Special Notes
If no other immobilizer related fault codes are stored and the immobilizer related meas. blocks are fine except Engine Start not allowed, try cold-booting the car. Remove both battery cables from the battery. Short the battery cables together (away from the battery) for about 15 seconds. Reconnect the battery.
00956 - Key 2
[edit]00956 - Key 2: Adaptation Limit Surpassed
Remote control not working.
Key not matched.
Key operated more than 200 times while out of range.
See vehicle specific page for synchronisation/adaptation procedures.
Es lo que tengo, los otros no me salen.
Suerte
De todas formas, lo que haría yo es un borrado de todos y vuelta a escanear, así verás cual está activo.
Porque me da a mi que esos no los tienes activos, son de alguna intervención y se quedaron sin borrar.
