agciaalo Publicado 4 de Marzo del 2007 Denunciar Publicado 4 de Marzo del 2007 Buenas noches, tras una instalación de un bluetooth que parecia satisfactoria ... he pasado el VAG y han aparecido problemas que no se qué son ni como solucionar... he revisado todos los cables, etc ... y encima todo funciona. ------------------------------------------------------------------------------- Address 08: Auto HVAC Part No: 8P0 820 043 H Component: KlimavollautomatH17 0200 2 Faults Found: 01299 - Diagnostic Interface for Data Bus (J533) 008 - Implausible Signal - Intermittent 01301 - Control Module for Voice Recognition (J507) 004 - No Signal/Communication - Intermittent ------------------------------------------------------------------------------- Address 09: Cent. Elect. Part No: 8P0 907 279 F Component: Bordnetz-SG H36 1201 Coding: 01884F068214100000000000000000000008FE175C0100 Shop #: WSC 06314 Part No: 8P1 955 119 B Component: Wischer AU350 H01 0130 Coding: 00062736 Shop #: WSC 06314 2 Faults Found: 01800 - Light Switch (E1) 008 - Implausible Signal - Intermittent 02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20) 009 - Open or Short to Ground - Intermittent ------------------------------------------------------------------------------- Address 19: CAN Gateway Part No: 1K0 907 530 F Component: Gateway H10 0120 Coding: 3D0F0BCA070100 Shop #: WSC 06314 1 Fault Found: 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication - Intermittent ------------------------------------------------------------------------------- Address 37: Navigation Part No: 8P0 035 192 Component: RNS-E HIGH EU H57 0450 Coding: 0205711 Shop #: WSC 42587 3 Faults Found: 00862 - Antenna for GPS Navigation (R50/R52) 011 - Open Circuit - Intermittent 00856 - Radio Antenna 011 - Open Circuit - Intermittent 00858 - Connection; Radio ZF Output to Antenna Amplifier 011 - Open Circuit - Intermittent ------------------------------------------------------------------------------- Address 56: Radio Part No: 8P0 035 192 Component: RNS-E HIGH EU H57 0450 Coding: 0205711 Shop #: WSC 42587 3 Faults Found: 00862 - Antenna for GPS Navigation (R50/R52) 011 - Open Circuit - Intermittent 00856 - Radio Antenna 011 - Open Circuit - Intermittent 00858 - Connection; Radio ZF Output to Antenna Amplifier 011 - Open Circuit - Intermittent ------------------------------------------------------------------------------- Me preocupan en especial los el modulo 09. El redto no los entiendo, el navegador funciona correctamente, señal, satelites, radio ... el bluetooth tambien ... ¿alguien puede echarme una mano? Muchas gracias de antemano. Responder
